[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_get.c |3
clones ( rem_get.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 11:28:20 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/rem_get.c functions
Clone analysis:
This file has 3 potentially cloned functions:
REM_get_location_with_line REM_get_location_with_box do_get
In lib/raster/rem_get.c clones of do_get are:
lib/raster/get.c do_get
In lib/raster/rem_get.c clones of REM_get_location_with_box are:
lib/raster/rem_get.c REM_get_location_with_line
In lib/raster/rem_get.c clones of REM_get_location_with_line are:
lib/raster/rem_get.c REM_get_location_with_box
Threshold GRASS6 key metrics values at 2006-07-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 249 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
