[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:44 EDT 2006
Hello brad,
ANALYSIS
display/d.profile/Range.c functions
WindowRange (Begins at: 5 Ends at: 51)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 47 | | OK |
metrics are OK
quick_range (Begins at: 53 Ends at: 78)
Complexity: | 6 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 26 | | OK |
metrics are OK
slow_range (Begins at: 81 Ends at: 111)
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
