[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:44 EDT 2006
Hello brad,
ANALYSIS
lib/btree/update.c functions
btree_update (Begins at: 7 Ends at: 77)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
store (Begins at: 79 Ends at: 91)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
