[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:47 EDT 2006
Hello cho,
ANALYSIS
display/d.save/main.c functions
main (Begins at: 50 Ends at: 374)
Complexity:   |      38 |   *** | MONSTER |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     325 |   *** | MONSTER |
2 metric are OUT OF RANGE!
in_frame_list (Begins at: 378 Ends at: 386)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
init_globals (Begins at: 389 Ends at: 402)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
which_item (Begins at: 428 Ends at: 436)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
set_item (Begins at: 440 Ends at: 494)
Complexity:   |      16 |     * |         |
CalledNBR:    |      21 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
process_list (Begins at: 498 Ends at: 529)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
process_items (Begins at: 534 Ends at: 556)
CalledNBR:    |       6 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
process_pad (Begins at: 560 Ends at: 573)
CalledNBR:    |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
