[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:47 EDT 2006
Hello cho,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 82 Ends at: 92)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
G_fatal_error (Begins at: 94 Ends at: 108)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_warning (Begins at: 110 Ends at: 123)
LOC: | 14 | | OK |
metrics are OK
G_suppress_warnings (Begins at: 125 Ends at: 132)
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
G_sleep_on_error (Begins at: 134 Ends at: 141)
LOC: | 8 | | OK |
metrics are OK
G_set_error_routine (Begins at: 143 Ends at: 147)
LOC: | 5 | | OK |
metrics are OK
G_unset_error_routine (Begins at: 149 Ends at: 154)
ParamNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
print_error (Begins at: 157 Ends at: 207)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 51 | | OK |
metrics are OK
log_error (Begins at: 209 Ends at: 244)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 36 | | OK |
metrics are OK
write_error (Begins at: 246 Ends at: 278)
Complexity: | 4 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 14 | | OK |
LOC: | 33 | | OK |
metrics are OK
mail_msg (Begins at: 280 Ends at: 298)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
print_word (Begins at: 301 Ends at: 352)
Complexity: | 9 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 52 | | OK |
metrics are OK
print_sentence (Begins at: 355 Ends at: 391)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 37 | | OK |
metrics are OK
G_info_format (Begins at: 393 Ends at: 408)
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
