[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
raster/r.in.ascii/gethead.c functions
getgrdhead (Begins at: 23 Ends at: 88)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 66 | | OK |
metrics are OK
gethead (Begins at: 90 Ends at: 252)
Complexity: | 35 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 50 | * | |
LOC: | 163 | * | |
at least 1 values are close to an outlier please consider revising code
scan_int (Begins at: 254 Ends at: 267)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 14 | | OK |
metrics are OK
scan_string (Begins at: 269 Ends at: 280)
Complexity: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
extract (Begins at: 282 Ends at: 301)
ParamNBR: | 6 | * | |
CalledNBR: | 7 | | OK |
LOC: | 20 | | OK |
missing (Begins at: 303 Ends at: 310)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
error (Begins at: 312 Ends at: 325)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
file_scan (Begins at: 329 Ends at: 349)
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
