[GRASS-QA] SOCCER LAB GRASS QA: 2 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c parser.c
GS2.c gethead.c ) 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
raster/r.in.arc/gethead.c functions
gethead (Begins at: 15 Ends at: 105)
Complexity: | 17 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 91 | | OK |
metrics are OK
scan_int (Begins at: 107 Ends at: 121)
Complexity: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
scan_res (Begins at: 123 Ends at: 137)
LOC: | 15 | | OK |
metrics are OK
scan_easting (Begins at: 140 Ends at: 143)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
scan_northing (Begins at: 145 Ends at: 148)
LOC: | 4 | | OK |
metrics are OK
scan_cellsize (Begins at: 150 Ends at: 153)
LOC: | 4 | | OK |
metrics are OK
extract (Begins at: 155 Ends at: 172)
Complexity: | 3 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 7 | | OK |
LOC: | 18 | | OK |
1 metric are OUT OF RANGE!
missing (Begins at: 174 Ends at: 181)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
error (Begins at: 183 Ends at: 196)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
scan_res scan_int
In raster/r.in.arc/gethead.c clones of scan_int are:
raster/r.in.arc/gethead.c scan_res
In raster/r.in.arc/gethead.c clones of scan_res are:
raster/r.in.arc/gethead.c scan_int
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
