[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
raster3d/base/r3.info.main.c functions
main (Begins at: 46 Ends at: 425)
Complexity:   |      47 |   *** | MONSTER |
CalledNBR:    |     195 |   *** | MONSTER |
LOC:          |     380 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 428 Ends at: 434)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
