[GRASS-QA] SOCCER LAB GRASS QA: 5 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c position.c get_row.c pad.c main.c main.c command.c parser.c GS2.c gethead.c anim_support.c draw.c position.c site_attr_commands.c site_highlight_commands.c ) 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/site_highlight_commands.c functions
site_highlight_get_int_BBGGRR (Begins at: 207 Ends at: 216)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
site_highlight_init_tcl (Begins at: 236 Ends at: 250)
CalledNBR:    |       9 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
site_highlight_get_geosite (Begins at: 254 Ends at: 269)
Complexity:   |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
site_highlight_get_geopoint (Begins at: 272 Ends at: 280)
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
site_highlight_loop (Begins at: 283 Ends at: 324)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      42 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Nsite_highlight_cmd (Begins at: 329 Ends at: 372)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Nsite_highlight_list_cmd (Begins at: 375 Ends at: 430)
Complexity:   |      21 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
Nsite_unhighlight_cmd (Begins at: 432 Ends at: 453)
Complexity:   |       8 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Nsite_unhighlight_list_cmd (Begins at: 455 Ends at: 489)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
Nsite_unhighlight_all_cmd (Begins at: 492 Ends at: 521)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Nsite_highlight_set_default_value_cmd (Begins at: 527 Ends at: 546)
Complexity:   |       5 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Nsite_highlight_get_default_value_cmd (Begins at: 548 Ends at: 569)
CalledNBR:    |       7 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Nsite_highlight_set_default_cmd (Begins at: 575 Ends at: 594)
LOC:          |      20 |       |      OK |
metrics are OK
Nsite_highlight_get_default_cmd (Begins at: 596 Ends at: 617)
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
  site_highlight_get_int_BBGGRR  Nsite_highlight_get_default_cmd  Nsite_highlight_get_default_value_cmd  Nsite_highlight_set_default_cmd  Nsite_highlight_set_default_value_cmd
In visualization/nviz/src/site_highlight_commands.c clones of  site_highlight_get_int_BBGGRR are:
	visualization/nviz/src/site_attr_commands.c  attr_get_int_BBGGRR
In visualization/nviz/src/site_highlight_commands.c clones of  Nsite_highlight_get_default_cmd are:
	visualization/nviz/src/site_highlight_commands.c  Nsite_highlight_get_default_value_cmd
In visualization/nviz/src/site_highlight_commands.c clones of  Nsite_highlight_set_default_cmd are:
	visualization/nviz/src/site_highlight_commands.c  Nsite_highlight_set_default_value_cmd
In visualization/nviz/src/site_highlight_commands.c clones of  Nsite_highlight_get_default_value_cmd are:
	visualization/nviz/src/site_highlight_commands.c  Nsite_highlight_get_default_cmd
In visualization/nviz/src/site_highlight_commands.c clones of  Nsite_highlight_set_default_value_cmd are:
	visualization/nviz/src/site_highlight_commands.c  Nsite_highlight_set_default_cmd
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
