[GRASS-QA] SOCCER LAB GRASS QA: 4 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c position.c get_row.c pad.c main.c main.c command.c parser.c GS2.c gethead.c anim_support.c draw.c position.c site_attr_commands.c ) 2 monsters and 6 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/site_attr_commands.c functions
site_attr_init_tcl (Begins at: 253 Ends at: 281)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Nsite_attr_get_fields_name_cmd (Begins at: 312 Ends at: 338)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Nsite_attr_get_fields_type_cmd (Begins at: 345 Ends at: 371)
LOC:          |      27 |       |      OK |
metrics are OK
Nsite_attr_get_fields_name_and_type_cmd (Begins at: 378 Ends at: 419)
CalledNBR:    |       9 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Nsite_attr_get_field_values_cmd (Begins at: 421 Ends at: 469)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Nsite_attr_get_field_not_emtpy_cats_cmd (Begins at: 471 Ends at: 520)
Complexity:   |       6 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Nsite_attr_get_record_values_cmd (Begins at: 522 Ends at: 578)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Nsite_attr_get_value_cmd (Begins at: 580 Ends at: 605)
Complexity:   |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
site_attr_open_map (Begins at: 607 Ends at: 622)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
at least 1 values are close to an outlier please consider revising code
site_attr_close_map (Begins at: 625 Ends at: 629)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
site_attr_init (Begins at: 641 Ends at: 648)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
site_attr_set (Begins at: 651 Ends at: 704)
Complexity:   |      18 |     * |         |
CalledNBR:    |      19 |       |      OK |
LOC:          |      54 |       |      OK |
site_attr_unset (Begins at: 706 Ends at: 720)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
site_attr_get (Begins at: 722 Ends at: 730)
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
site_attr_set_color (Begins at: 734 Ends at: 767)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       6 |     * |         |
LOC:          |      34 |       |      OK |
site_attr_set_size (Begins at: 769 Ends at: 803)
CalledNBR:    |      13 |       |      OK |
LOC:          |      35 |       |      OK |
site_attr_set_fixed_color (Begins at: 805 Ends at: 810)
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
site_attr_set_fixed_size (Begins at: 812 Ends at: 817)
LOC:          |       6 |       |      OK |
metrics are OK
site_attr_set_fixed_marker (Begins at: 819 Ends at: 838)
LOC:          |      20 |       |      OK |
metrics are OK
attr_get_int_BBGGRR (Begins at: 840 Ends at: 849)
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
attr_get_RRGGBB (Begins at: 852 Ends at: 870)
LOC:          |      19 |       |      OK |
metrics are OK
attr_get_char_RRGGBB (Begins at: 873 Ends at: 896)
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Nget_interpolated_values_cmd (Begins at: 898 Ends at: 983)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
attr_interp_entries (Begins at: 985 Ends at: 1009)
LOC:          |      25 |       |      OK |
attr_interp_entries_string (Begins at: 1011 Ends at: 1017)
LOC:          |       7 |       |      OK |
metrics are OK
attr_interp_colors (Begins at: 1019 Ends at: 1058)
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      12 |       |      OK |
LOC:          |      40 |       |      OK |
1 metric are OUT OF RANGE!
attr_interp_colors_string (Begins at: 1060 Ends at: 1074)
LOC:          |      15 |       |      OK |
metrics are OK
attr_eval_entry (Begins at: 1078 Ends at: 1088)
LOC:          |      11 |       |      OK |
metrics are OK
attr_eval_entry_string (Begins at: 1090 Ends at: 1100)
LOC:          |      11 |       |      OK |
metrics are OK
attr_eval_color (Begins at: 1102 Ends at: 1122)
ParamNBR:     |       9 |   *** | MONSTER |
LOC:          |      21 |       |      OK |
attr_eval_color_string (Begins at: 1124 Ends at: 1136)
LOC:          |      13 |       |      OK |
Clone analysis:
This file has 4 potentially cloned functions:
  attr_get_int_BBGGRR  Nsite_attr_get_fields_type_cmd  Nsite_attr_get_fields_name_cmd  site_attr_get
In visualization/nviz/src/site_attr_commands.c clones of  site_attr_get are:
	ps/ps.map/do_header.c  apply
In visualization/nviz/src/site_attr_commands.c clones of  Nsite_attr_get_fields_name_cmd are:
	visualization/nviz/src/site_attr_commands.c  Nsite_attr_get_fields_type_cmd
In visualization/nviz/src/site_attr_commands.c clones of  attr_get_int_BBGGRR are:
	visualization/nviz/src/site_highlight_commands.c  site_highlight_get_int_BBGGRR
In visualization/nviz/src/site_attr_commands.c clones of  Nsite_attr_get_fields_type_cmd are:
	visualization/nviz/src/site_attr_commands.c  Nsite_attr_get_fields_name_cmd
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
