[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:46 EDT 2006
Hello brad,
ANALYSIS
raster/r.to.vect/lines.c functions
extract_lines (Begins at: 62 Ends at: 185)
Complexity: | 18 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 46 | * | |
LOC: | 124 | * | |
metrics are OK
nabors (Begins at: 187 Ends at: 209)
Complexity: | 9 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 23 | | OK |
metrics are OK
update_list (Begins at: 211 Ends at: 484)
Complexity: | 79 | *** | MONSTER |
CalledNBR: | 74 | ** | Warning |
LOC: | 274 | *** | MONSTER |
2 metric are OUT OF RANGE!
end_line (Begins at: 486 Ends at: 495)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
start_line (Begins at: 497 Ends at: 509)
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
join_lines (Begins at: 511 Ends at: 538)
Complexity: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
extend_line (Begins at: 540 Ends at: 594)
CalledNBR: | 7 | | OK |
LOC: | 55 | | OK |
metrics are OK
get_ptr (Begins at: 596 Ends at: 607)
LOC: | 12 | | OK |
metrics are OK
alloc_lines_bufs (Begins at: 609 Ends at: 624)
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
read_next (Begins at: 626 Ends at: 637)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
