[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Tue Jun 13 05:58:46 EDT 2006
Hello brad,
ANALYSIS
raster/r.to.vect/areas_io.c functions
write_boundary (Begins at: 34 Ends at: 74)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
write_bnd (Begins at: 79 Ends at: 145)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
write_smooth_bnd (Begins at: 152 Ends at: 253)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
write_area (Begins at: 256 Ends at: 346)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      91 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
