[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c ) 0 monsters
and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:46 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/vect.c functions
open_new_vect (Begins at: 9 Ends at: 17)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 9 | | OK |
metrics are OK
close_vect (Begins at: 23 Ends at: 32)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
open_new_vect
In raster/r.carve/vect.c clones of open_new_vect are:
vector/v.buffer/main.c stop
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
