[GRASS-QA] SOCCER LAB GRASS QA: 2 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c parser.c
GS2.c gethead.c anim_support.c draw.c position.c
site_attr_commands.c site_highlight_commands.c
togl_flythrough.c parser.c raster.c line.c ) 1 monsters and 2
warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:56 EDT 2006
Hello markus,
ANALYSIS
lib/vector/Vlib/line.c functions
Vect_new_line_struct (Begins at: 35 Ends at: 43)
Complexity: | 2 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Vect__new_line_struct (Begins at: 46 Ends at: 60)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
Vect_destroy_line_struct (Begins at: 69 Ends at: 90)
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 22 | | OK |
metrics are OK
Vect_copy_xyz_to_pnts (Begins at: 93 Ends at: 123)
ParamNBR: | 5 | * | |
LOC: | 31 | | OK |
metrics are OK
Vect_reset_line (Begins at: 126 Ends at: 140)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 15 | | OK |
metrics are OK
Vect_append_point (Begins at: 143 Ends at: 165)
ParamNBR: | 4 | | OK |
LOC: | 23 | | OK |
metrics are OK
Vect_line_insert_point (Begins at: 168 Ends at: 196)
LOC: | 29 | | OK |
metrics are OK
Vect_line_delete_point (Begins at: 199 Ends at: 217)
ParamNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
Vect_line_prune (Begins at: 226 Ends at: 246)
LOC: | 21 | | OK |
metrics are OK
Vect_line_prune_thresh (Begins at: 255 Ends at: 275)
LOC: | 21 | | OK |
metrics are OK
Vect_append_points (Begins at: 278 Ends at: 315)
ParamNBR: | 3 | | OK |
LOC: | 38 | | OK |
metrics are OK
Vect_copy_pnts_to_xyz (Begins at: 318 Ends at: 352)
LOC: | 35 | | OK |
metrics are OK
Vect_point_on_line (Begins at: 355 Ends at: 442)
Complexity: | 11 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 88 | | OK |
at least 1 values are close to an outlier please consider revising code
Vect_line_segment (Begins at: 445 Ends at: 487)
Complexity: | 5 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 43 | | OK |
metrics are OK
Vect_line_length (Begins at: 496 Ends at: 518)
LOC: | 23 | | OK |
metrics are OK
Vect_line_geodesic_length (Begins at: 521 Ends at: 564)
LOC: | 44 | | OK |
metrics are OK
Vect_line_distance (Begins at: 567 Ends at: 663)
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 8 | | OK |
LOC: | 97 | | OK |
1 metric are OUT OF RANGE!
Vect_points_distance (Begins at: 666 Ends at: 683)
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
Vect_line_box (Begins at: 692 Ends at: 696)
LOC: | 5 | | OK |
metrics are OK
Vect_line_reverse (Begins at: 704 Ends at: 732)
LOC: | 29 | | OK |
metrics are OK
Vect_get_line_cat (Begins at: 735 Ends at: 748)
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
Vect_new_line_struct Vect__new_line_struct
In lib/vector/Vlib/line.c clones of Vect_new_line_struct are:
lib/vector/Vlib/cats.c Vect_new_cats_struct
In lib/vector/Vlib/line.c clones of Vect__new_line_struct are:
lib/vector/Vlib/cats.c Vect__new_cats_struct
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
