[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
lib/ogsf/gsd_img.c functions
ierrfunc (Begins at: 15 Ends at: 20)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
GS_write_rgb (Begins at: 22 Ends at: 64)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 43 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
