[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
lib/ogsf/gsd_img_ppm.c functions
GS_write_ppm (Begins at: 33 Ends at: 66)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
GS_write_zoom (Begins at: 68 Ends at: 99)
ParamNBR:     |       3 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
gsd_init_mpeg (Begins at: 106 Ends at: 204)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
gsd_write_mpegframe (Begins at: 211 Ends at: 254)
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
gsd_close_mpeg (Begins at: 260 Ends at: 292)
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
