[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello hamish,
ANALYSIS
lib/db/dbmi_base/valuefmt.c functions
db_convert_Cstring_to_value (Begins at: 13 Ends at: 40)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
db_convert_value_to_string (Begins at: 49 Ends at: 82)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
