[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello hamish,
ANALYSIS
display/d.vect/main.c functions
icon_files (Begins at: 32 Ends at: 78)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
test_bg_color (Begins at: 81 Ends at: 96)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
main (Begins at: 99 Ends at: 647)
Complexity:   |      75 |   *** | MONSTER |
CalledNBR:    |     181 |   *** | MONSTER |
LOC:          |     549 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
