[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:56 EDT 2006
Hello radim,
ANALYSIS
vector/v.distance/main.c functions
main (Begins at: 65 Ends at: 989)
Complexity:   |     155 |   *** | MONSTER |
CalledNBR:    |     251 |   *** | MONSTER |
LOC:          |     925 |   *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_near (Begins at: 991 Ends at: 998)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
cmp_exist (Begins at: 1000 Ends at: 1008)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
