[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:56 EDT 2006
Hello paul,
ANALYSIS
lib/proj/get_proj.c functions
pj_get_kv (Begins at: 61 Ends at: 242)
Complexity:   |      23 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     182 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
alloc_options (Begins at: 244 Ends at: 253)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
pj_get_string (Begins at: 255 Ends at: 351)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
GPJ_get_equivalent_latlong (Begins at: 353 Ends at: 362)
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
set_proj_lib (Begins at: 367 Ends at: 395)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
pj_print_proj_params (Begins at: 397 Ends at: 424)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
