[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/nviz_init.c functions
parse_command (Begins at: 26 Ends at: 326)
Complexity:   |      26 |    ** | Warning |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     301 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Ngetargs (Begins at: 328 Ends at: 360)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
make_red_yellow_ramp (Begins at: 362 Ends at: 373)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
sort_surfs_mid (Begins at: 380 Ends at: 410)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
set_default_wirecolors (Begins at: 412 Ends at: 442)
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Ninit (Begins at: 444 Ends at: 469)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Ninitdata (Begins at: 473 Ends at: 494)
CalledNBR:    |       6 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
