[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 4 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 14 05:01:08 EDT 2006
Hello markus,
ANALYSIS
lib/vector/Vlib/field.c functions
Vect_new_dblinks_struct (Begins at: 36 Ends at: 48)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Vect_reset_dblinks (Begins at: 57 Ends at: 67)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Vect_map_add_dblink (Begins at: 70 Ends at: 97)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      28 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Vect_map_del_dblink (Begins at: 106 Ends at: 141)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Vect_map_check_dblink (Begins at: 150 Ends at: 153)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_check_dblink (Begins at: 162 Ends at: 182)
LOC:          |      21 |       |      OK |
metrics are OK
Vect_add_dblink (Begins at: 185 Ends at: 222)
Complexity:   |       8 |       |      OK |
LOC:          |      38 |       |      OK |
Vect_default_field_info (Begins at: 231 Ends at: 305)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
Vect_get_dblink (Begins at: 308 Ends at: 340)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Vect_get_field (Begins at: 343 Ends at: 358)
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Vect_read_dblinks (Begins at: 367 Ends at: 561)
Complexity:   |      18 |     * |         |
CalledNBR:    |      58 |    ** | Warning |
LOC:          |     195 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Vect_write_dblinks (Begins at: 570 Ends at: 606)
CalledNBR:    |      11 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Vect_subst_var (Begins at: 615 Ends at: 654)
CalledNBR:    |      16 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
Vect_set_db_updated (Begins at: 662 Ends at: 669)
CalledNBR:    |       5 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
