[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 14 05:01:08 EDT 2006
Hello markus,
ANALYSIS
raster/r.lake/main.c functions
save_map (Begins at: 41 Ends at: 83)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      14 |       |      OK |
LOC:          |      43 |       |      OK |
1 metric are OUT OF RANGE!
is_near_water (Begins at: 86 Ends at: 103)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
load_window_values (Begins at: 106 Ends at: 138)
ParamNBR:     |       6 |     * |         |
LOC:          |      33 |       |      OK |
at least 1 values are close to an outlier please consider revising code
main (Begins at: 140 Ends at: 422)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |     111 |   *** | MONSTER |
LOC:          |     283 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
