[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 14 17:41:44 EDT 2006
Hello cho,
ANALYSIS
lib/vector/Vlib/dbcolumns.c functions
Vect_get_column_names (Begins at: 34 Ends at: 86)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
Vect_get_column_types (Begins at: 94 Ends at: 153)
CalledNBR:    |      27 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
Vect_get_column_names_types (Begins at: 155 Ends at: 209)
CalledNBR:    |      31 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
