[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 14 17:41:44 EDT 2006
Hello cho,
ANALYSIS
lib/vector/Vlib/close_ogr.c functions
V1_close_ogr (Begins at: 27 Ends at: 51)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
V2_close_ogr (Begins at: 60 Ends at: 113)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
