[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 14 17:41:43 EDT 2006
Hello cho,
ANALYSIS
lib/vector/Vlib/build_ogr.c functions
init_parts (Begins at: 50 Ends at: 54)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
reset_parts (Begins at: 57 Ends at: 60)
LOC: | 4 | | OK |
metrics are OK
free_parts (Begins at: 63 Ends at: 67)
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
add_part (Begins at: 70 Ends at: 78)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
del_part (Begins at: 81 Ends at: 84)
LOC: | 4 | | OK |
metrics are OK
add_parts_to_offset (Begins at: 87 Ends at: 103)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
add_line (Begins at: 106 Ends at: 141)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 9 | | OK |
LOC: | 36 | | OK |
metrics are OK
add_geometry (Begins at: 148 Ends at: 298)
Complexity: | 15 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 59 | ** | Warning |
LOC: | 151 | * | |
at least 1 values are close to an outlier please consider revising code
Vect_build_ogr (Begins at: 307 Ends at: 375)
Complexity: | 7 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 69 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
