[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Thu Jun 15 05:02:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 24 Ends at: 602)
Complexity:   |      85 |   *** | MONSTER |
CalledNBR:    |     199 |   *** | MONSTER |
LOC:          |     579 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 606 Ends at: 694)
Complexity:   |      16 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-15 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
