[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Jun 15 05:12:25 EDT 2006
Hello markus,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 24 Ends at: 609)
Complexity: | 86 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 201 | *** | MONSTER |
LOC: | 586 | *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 613 Ends at: 705)
Complexity: | 17 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 24 | | OK |
LOC: | 93 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
