[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 10:11:24 EDT 2006
Hello markus,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 24 Ends at: 609)
Complexity:   |      86 |   *** | MONSTER |
CalledNBR:    |     201 |   *** | MONSTER |
LOC:          |     586 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 613 Ends at: 705)
Complexity:   |      17 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |      93 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
