[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 11:35:31 EDT 2006
Hello soeren,
ANALYSIS
raster/r.out.vtk/main.c functions
CheckInputMaps (Begins at: 36 Ends at: 122)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
main (Begins at: 128 Ends at: 393)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     266 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
