[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 14:19:07 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.out.vtk/writeVTKHead.c functions
writeVTKStructuredPointHeader (Begins at: 34 Ends at: 88)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 55 | | OK |
metrics are OK
writeVTKStructuredGridHeader (Begins at: 94 Ends at: 109)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 16 | | OK |
metrics are OK
writeVTKUnstructuredGridHeader (Begins at: 114 Ends at: 127)
CalledNBR: | 7 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
