[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jun 17 05:04:56 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/drawvect.c functions
plotvect (Begins at: 18 Ends at: 21)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
zoomvect (Begins at: 23 Ends at: 26)
LOC: | 4 | | OK |
metrics are OK
re_fresh_vect (Begins at: 28 Ends at: 31)
LOC: | 4 | | OK |
metrics are OK
warpvect (Begins at: 33 Ends at: 36)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
drawvect (Begins at: 38 Ends at: 261)
Complexity: | 20 | * | |
ParamNBR: | 5 | * | |
CalledNBR: | 65 | ** | Warning |
LOC: | 224 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
choose_vectfile (Begins at: 263 Ends at: 266)
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
get_clr_name (Begins at: 268 Ends at: 297)
Complexity: | 8 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 30 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
