[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 20 06:03:18 EDT 2006
Hello markus,
ANALYSIS
raster/r.surf.idw2/main.c functions
main (Begins at: 23 Ends at: 182)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 42 | * | |
LOC: | 160 | * | |
metrics are OK
newpoint (Begins at: 185 Ends at: 199)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
