[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 4 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 20 06:12:26 EDT 2006
Hello markus,
ANALYSIS
raster/r.surf.idw/main.c functions
main (Begins at: 28 Ends at: 152)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     125 |     * |         |
metrics are OK
lookup_and_function_ptrs (Begins at: 154 Ends at: 187)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
interpolate (Begins at: 190 Ends at: 278)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      89 |       |      OK |
at least 1 values are close to an outlier please consider revising code
make_neighbors_list (Begins at: 280 Ends at: 343)
Complexity:   |      11 |       |      OK |
LOC:          |      64 |       |      OK |
search (Begins at: 348 Ends at: 394)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
1 metric are OUT OF RANGE!
exhaust (Begins at: 397 Ends at: 423)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
offset_distance (Begins at: 425 Ends at: 428)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
completed_row (Begins at: 434 Ends at: 437)
LOC:          |       4 |       |      OK |
metrics are OK
next_row (Begins at: 440 Ends at: 455)
Complexity:   |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
first_west (Begins at: 463 Ends at: 477)
Complexity:   |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
find_neighbors (Begins at: 485 Ends at: 513)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      29 |       |      OK |
exhaust_search (Begins at: 520 Ends at: 542)
LOC:          |      23 |       |      OK |
metrics are OK
triangulate (Begins at: 549 Ends at: 557)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
add_neighbor (Begins at: 560 Ends at: 575)
LOC:          |      16 |       |      OK |
metrics are OK
replace_neighbor (Begins at: 578 Ends at: 600)
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
sort_neighbors (Begins at: 603 Ends at: 616)
LOC:          |      14 |       |      OK |
metrics are OK
free_row_lists (Begins at: 620 Ends at: 637)
LOC:          |      18 |       |      OK |
metrics are OK
row_lists (Begins at: 640 Ends at: 700)
LOC:          |      61 |       |      OK |
lookup_tables (Begins at: 707 Ends at: 725)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-20 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
