[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 20 09:56:31 EDT 2006
Hello hamish,
ANALYSIS
vector/v.digit/main.c functions
Tcl_AppInit (Begins at: 25 Ends at: 87)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 63 | | OK |
metrics are OK
main (Begins at: 89 Ends at: 207)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 119 | * | |
at least 1 values are close to an outlier please consider revising code
end (Begins at: 210 Ends at: 227)
Complexity: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
