[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 20 23:27:26 EDT 2006
Hello brad,
ANALYSIS
vector/v.distance/main.c functions
main (Begins at: 68 Ends at: 991)
Complexity:   |     155 |   *** | MONSTER |
CalledNBR:    |     292 |   *** | MONSTER |
LOC:          |     924 |   *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_near (Begins at: 994 Ends at: 1001)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
cmp_exist (Begins at: 1004 Ends at: 1012)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-20 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
