[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/input.c |5 clones ( analyze.c drawcell.c driver.c input.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 23 04:11:41 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/input.c functions
Input_pointer (Begins at: 19 Ends at: 22)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Input_box (Begins at: 24 Ends at: 27)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Input_other (Begins at: 29 Ends at: 45)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
mouse (Begins at: 47 Ends at: 103)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
use_mouse_msg (Begins at: 106 Ends at: 111)
LOC:          |       6 |       |      OK |
metrics are OK
draw_objects (Begins at: 113 Ends at: 177)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
find (Begins at: 179 Ends at: 201)
Complexity:   |       7 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
select_option (Begins at: 203 Ends at: 215)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
draw_option_boxes (Begins at: 217 Ends at: 235)
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
visible (Begins at: 237 Ends at: 242)
LOC:          |       6 |       |      OK |
metrics are OK
Menu_msg (Begins at: 244 Ends at: 264)
LOC:          |      21 |       |      OK |
metrics are OK
Start_mouse_in_menu (Begins at: 266 Ends at: 273)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
  Menu_msg  draw_objects  find  select_option  draw_option_boxes
In imagery/i.vpoints/input.c clones of  select_option are:
	imagery/i.points/input.c  select_option
	imagery/i.ortho.photo/photo.2target/input.c  select_option
	imagery/i.ortho.photo/photo.2image/input.c  select_option
	imagery/i.class/input.c  select_option
In imagery/i.vpoints/input.c clones of  Menu_msg are:
	imagery/i.points/input.c  Menu_msg
	imagery/i.ortho.photo/photo.2target/input.c  Menu_msg
	imagery/i.ortho.photo/photo.2image/input.c  Menu_msg
	imagery/i.class/input.c  Menu_msg
In imagery/i.vpoints/input.c clones of  draw_option_boxes are:
	imagery/i.points/input.c  draw_option_boxes
	imagery/i.ortho.photo/photo.2target/input.c  draw_option_boxes
	imagery/i.ortho.photo/photo.2image/input.c  draw_option_boxes
	imagery/i.class/input.c  draw_option_boxes
In imagery/i.vpoints/input.c clones of  find are:
	imagery/i.points/input.c  find
	imagery/i.ortho.photo/photo.2target/input.c  find
	imagery/i.ortho.photo/photo.2image/input.c  find
	imagery/i.class/input.c  find
In imagery/i.vpoints/input.c clones of  draw_objects are:
	imagery/i.points/input.c  draw_objects
	imagery/i.ortho.photo/photo.2target/input.c  draw_objects
	imagery/i.ortho.photo/photo.2image/input.c  draw_objects
	imagery/i.class/input.c  draw_objects
Threshold GRASS6 key metrics values at 2006-06-23 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
