[GRASS-QA] GRASS QA: markus | ./grass6/lib/init/clean_temp.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jun 24 14:33:02 EDT 2006
Hello markus,
ANALYSIS
lib/init/clean_temp.c functions
clean_dir (Begins at: 38 Ends at: 103)
Complexity: | 16 | * | |
ParamNBR: | 5 | * | |
CalledNBR: | 30 | | OK |
LOC: | 66 | | OK |
metrics are OK
main (Begins at: 106 Ends at: 157)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 52 | | OK |
metrics are OK
find_process (Begins at: 160 Ends at: 168)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
