[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/colors.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 06:34:57 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/colors.c functions
set_colors (Begins at: 21 Ends at: 164)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |     144 |     * |         |
metrics are OK
get_vector_color (Begins at: 166 Ends at: 184)
LOC:          |      19 |       |      OK |
metrics are OK
setmap_blue (Begins at: 186 Ends at: 189)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
setmap_gray (Begins at: 191 Ends at: 194)
LOC:          |       4 |       |      OK |
metrics are OK
setmap_green (Begins at: 196 Ends at: 199)
LOC:          |       4 |       |      OK |
metrics are OK
setmap_red (Begins at: 201 Ends at: 204)
LOC:          |       4 |       |      OK |
metrics are OK
setmap_white (Begins at: 206 Ends at: 209)
LOC:          |       4 |       |      OK |
metrics are OK
setmap_yellow (Begins at: 211 Ends at: 214)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
