[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/drawvect.c |no clones | 0 monsters | 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 06:34:57 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/drawvect.c functions
plotvect (Begins at: 24 Ends at: 27)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
zoomvect (Begins at: 29 Ends at: 32)
LOC:          |       4 |       |      OK |
metrics are OK
re_fresh_vect (Begins at: 34 Ends at: 37)
LOC:          |       4 |       |      OK |
metrics are OK
warpvect (Begins at: 39 Ends at: 42)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
drawvect (Begins at: 45 Ends at: 279)
Complexity:   |      23 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      64 |    ** | Warning |
LOC:          |     235 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
choose_vectfile (Begins at: 281 Ends at: 284)
LOC:          |       4 |       |      OK |
metrics are OK
get_clr_name (Begins at: 286 Ends at: 315)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
