[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/ExtractProf.c
|no clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 16:08:02 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/ExtractProf.c functions
ExtractProfile (Begins at: 47 Ends at: 319)
Complexity: | 33 | ** | Warning |
ParamNBR: | 3 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 273 | *** | MONSTER |
1 metric are OUT OF RANGE!
ucat_max (Begins at: 321 Ends at: 344)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
ucat_min (Begins at: 347 Ends at: 367)
Complexity: | 8 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
