[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/main.c |no
clones | 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 16:08:02 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/main.c functions
main (Begins at: 26 Ends at: 424)
Complexity: | 38 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 161 | *** | MONSTER |
LOC: | 399 | *** | MONSTER |
3 metric are OUT OF RANGE!
myDcell (Begins at: 426 Ends at: 468)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 43 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
