[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/Range.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 16:08:03 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/Range.c functions
WindowRange (Begins at: 5 Ends at: 51)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
quick_range (Begins at: 53 Ends at: 78)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
slow_range (Begins at: 81 Ends at: 111)
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
