[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/utils.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 16:08:03 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/utils.c functions
is_null_value (Begins at: 4 Ends at: 28)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
