[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.points/main.c |no
clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 08:29:19 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.points/main.c functions
main (Begins at: 21 Ends at: 145)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 57 | ** | Warning |
LOC: | 125 | * | |
at least 1 values are close to an outlier please consider revising code
quit (Begins at: 147 Ends at: 170)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 24 | | OK |
metrics are OK
error (Begins at: 172 Ends at: 197)
Complexity: | 3 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
