[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.group/main.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 11:42:18 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.group/main.c functions
main (Begins at: 21 Ends at: 130)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 43 | * | |
LOC: | 110 | | OK |
metrics are OK
add_or_update_group (Begins at: 133 Ends at: 167)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 35 | | OK |
metrics are OK
add_or_update_subgroup (Begins at: 170 Ends at: 204)
ParamNBR: | 4 | | OK |
LOC: | 35 | | OK |
metrics are OK
remove_group_files (Begins at: 207 Ends at: 249)
Complexity: | 3 | | OK |
LOC: | 43 | | OK |
metrics are OK
remove_subgroup_files (Begins at: 252 Ends at: 295)
LOC: | 44 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
