[GRASS-QA] GRASS QA: cho | ./grass6/display/d.measure/msurements.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
display/d.measure/msurements.c functions
measurements (Begins at: 9 Ends at: 132)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      45 |     * |         |
LOC:          |     124 |     * |         |
metrics are OK
print_en (Begins at: 134 Ends at: 149)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
print_length (Begins at: 151 Ends at: 164)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
add_point (Begins at: 166 Ends at: 185)
ParamNBR:     |       6 |     * |         |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
