[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/main.c |no
clones | 2 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/main.c functions
main (Begins at: 26 Ends at: 395)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 169 | *** | MONSTER |
LOC: | 370 | *** | MONSTER |
2 metric are OUT OF RANGE!
myDcell (Begins at: 397 Ends at: 439)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 43 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
