[GRASS-QA] GRASS QA: cho | ./grass6/display/d.rast.edit/edit.c |1
clones ( edit.c )| 2 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
display/d.rast.edit/edit.c functions
edit (Begins at: 22 Ends at: 315)
Complexity: | 24 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 82 | *** | MONSTER |
LOC: | 294 | *** | MONSTER |
2 metric are OUT OF RANGE!
edit_mouse_info (Begins at: 317 Ends at: 329)
Complexity: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 13 | | OK |
metrics are OK
edit_mouse_info2 (Begins at: 331 Ends at: 364)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 34 | | OK |
metrics are OK
use_mouse (Begins at: 367 Ends at: 376)
CalledNBR: | 5 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
use_mouse
In display/d.rast.edit/edit.c clones of use_mouse are:
imagery/i.class/signature.c write_signatures
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
