[GRASS-QA] GRASS QA: cho | ./grass6/display/d.rast.edit/main.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
display/d.rast.edit/main.c functions
main (Begins at: 28 Ends at: 115)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 88 | | OK |
metrics are OK
do_edit (Begins at: 118 Ends at: 154)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 37 | | OK |
metrics are OK
error (Begins at: 156 Ends at: 183)
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
ext (Begins at: 187 Ends at: 194)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
